Because looking at a benchmark which remain much the same regardless of what you do is boring.
How much would a 200GB SSD cost?
I never see the point in "short stroking".
You are just arbitrarily limiting your harddrive space without any benefit.
It only looks good in benchmarks because they only tell you the "average" in benchmarks.
Can you do another test setup a 200gig partion and then partition the rest and bench it see if there is a big difference ?
I tried to bench this first, but I couldn't find a good program that would bench only the partition. HDTach benches the whole drive. (I foresee the results being the same if I had 2 partitions and only benched the first partition)
Wow, talk about dead wrong. What have you read to espouse such nonsense? Install an aftermarket defragmenter and do a scan which will show you the physical location of data on the drive. You will find the data scattered all over the drive until you actually complete a defragmentation run. Windows based defragmenters won't even do this.Modern (and not so modern) filesystems do that for you already anyways. They store data starting from the beginning (outer ring). So if you only have 20GB of your 640GB drive (partition) filled, it will perform the same as if you "short stroked" it to 20GB. Except you can use more space if you want, and you will always be using the fastest part.
haha yes I know latency matters. I use a SSD.Its all about latency man..
But its all heresay till you try it yourself
If it's a new drive, and you start writing files to it, it will start filling up from the beginning.Wow, talk about dead wrong. What have you read to espouse such nonsense? Install an aftermarket defragmenter and do a scan which will show you the physical location of data on the drive. You will find the data scattered all over the drive until you actually complete a defragmentation run. Windows based defragmenters won't even do this.
File fragmentation and data placement are two different things. Speaking of data placement as I was, programs like Perfect Disk do this when file defragmenting and benefits of doing so are documented.Fragmentation happens because files are deleted, and it would be costly (in terms of performance) to defrag whenever such a gap appears. The reason why they are not doing it is because they figured the performance increase of moving everything to the front is not enough to justify the time it takes to do it. That's the reason why almost-full partitions are slower. You are forcing the filesystem driver to eliminate any gap in order to fit in more data. And you are essentially telling it to defrag on every write, which is slow.
BS. Can that happen? Sometimes. I certainly don't claim to know exactly how data placement is determined, but the software is there to determine where it is. Do a fresh install and map the data, it's all over place. Take an empty drive used for data, throw some MP3's and video files on it, map it. Heck, I've thrown my page file on an empty drive and I still have to use Perfect Disk to move it to the front of the disk before dumping data on it.If it's a new drive, and you start writing files to it, it will start filling up from the beginning.
Do you have any scientific sources, besides personal anecdote, to back up your claim? Nothing is anecdotal about it. The results can be repeated over and over.
I tried researching for this issue, and it seems like information is few and far between. I agree.
May be easier for us to just conduct the test ourselves. I've done so many times on multiple builds and installs(Windows environment where most of us are). I stated my findings and stand behind them. I'd bet anyone else's results would be similar.
Have anyone tried a file-based (not disk or partition based) benchmark? bonnie++? (it's pretty unheard of here, but it's a very popular extensive benchmark outside of Windows world) Not a benchmark, but Perfect Disk, Disk Keeper, O&O Defrag, etc all can optimize windows system files("smart placement") in order to speed the boot process. I've picked up a few seconds here and there testing a fresh vs. optimized install. I used to keep such data, I really don't care to anymore. You can use the software to analyze file placement as well.
I'm not exactly in the mood of re-formatting my harddrives a few times, and plus, I am on a SSD. Since Bios24 already has this set up, can you run it? (Or anyone else, if you want to). I'm not interested either, I know how the story ends. Take care.
Note that I am not arguing whether defrag helps. It's whether short stroking helps.Not a benchmark, but Perfect Disk, Disk Keeper, O&O Defrag, etc all can optimize windows system files("smart placement") in order to speed the boot process. I've picked up a few seconds here and there testing a fresh vs. optimized install. I used to keep such data, I really don't care to anymore.
Not with a hardware based short-stoke as the OP which I consider the hard way to do what a partition or another RAID array via Intel's Matrix RAID would do. And yes, the files end up in the same place with the same boot times and programs launch times. What's behind it in the empty space, whether just free space, another partition(formatted or uninitialized) or say another RAID array using Intel MATRIX RAID doesn't matter in my tests. My final say on short-stroking is if you have a program like Perfect Disk, it will improve upon file placement instead of just squeezing files closer together with no optimization and negate the benefit of short-stroking. This may very well be worth a handful of seconds, but that's part of the "hobby" right?Note that I am not arguing whether defrag helps. It's whether short stroking helps.
Have you tried short-stroked optimized vs non-short-stroked optimized?
My arguement was with your statement on default file placement on hard drives within Windows OS'. It isn't "fastest to slowest", it's a bit random. Short-stroking confines the random placement and $30 software guarantees the best placement. Either is worth a handful of seconds at best.Ah, so you DO agree that short stroking really doesn't help . Might as well have free space behind the data.
