- Mar 3, 2002
Just a little somethin 2 add... more in the next post
Didn't write these just collected them all up cuz u can't find em all in one place... since we are tweaking software and all here is the fix up for kazaa....
First lets get rid of those nasty banner adds... this one is easy
go to c:\%windir%\system32 there should be a folder in there called AdCache go into that and delete everything, then get back out and right click on it and go to properties. click the security tab. In the group or username box select your username. In the permissions box deny write access. do this for all users (and administrators) now kazaa can't write to that folder, poof no more adds.
Now lets make it so you can look for audio files at higher bit rates than 128 (which is stupid, I miss napster)
okay open regedit and go to
HKEY_CURRENT_USER\Software\Kazaa
there should be a LimitBitrate value there... change it from 1 to 0
Last but not least lets bump up the max search results
1. Run regedit.
2. Goto: HKEY_CURRENT_USER/Software/Kazaa/Advanced
3. Open MaxSearchResult
4. Enter value data as 190
You now have a maximum search result of 400 instead of the usual 100!
Like I said I didn't come up with any of these... but they are nice all the same....
- Dimorphios
1. Run regedit.
- Dimorphios
