I'm thinking to build an amd itx pc. The stock cooler will just fit with little to no room above it. My budget is tight and liquid coolers are quiet expensive in India can't fit in my budget I'm thinking to go for antec vp600p psu it's a 80+ bronze (not certified but OEM model have) my build consist of ryzen5 1600 and gtx1070fe not considering to oc, so max power usage will be less than 350w.
Will there be any problem if I just open (ik warranty will be void) and reverse the fan of psu so that it will take air from outside and blow towards CPU heatsink.
