- Jun 16, 2006
Introduction.
Arctic Cooling is a very well known company for making top of the line performance computer cooling products.
In this review, we will be looking at the Freezer 64 Pro With PWM Fan Control to see if it lives up to Arctic Cooling's
reputation for great provenance.
The Product.
The Freezer 64 Pro is a performance heat sink for AMD's Socket 754 ,939 and the new AM2 Socket. This product
supports processors such at Athlon 64 FX-62 and Athlon 64 X2 5000+. Some of the features of this product are.
-Extremely Quiet Operation
-Patented Fan Casing
-6 6.0mm heat pipes
-Fan Speed Control Over PWM Signal 900-2200RPM
-Long Service Life
-Patented Vibration Absorption
-6 Year Warranty
-Easy Installation
-Pre applied MX-1 Performance Thermal Compound
-Cools Motherboard Voltage Converters
What's in the package"
-Freezer 64 Pro With PWM Control
-Instruction Manual
-Arctic Cooling Case Badge
Technical Data
Heat Sink: 104 x 58 x 126.5 mm
Fan: 107 x 43.5 x 96 mm
Overall Dimensions: 107 x 96.5 x 126.5 mm
Rated Fan Speed: 2200 RPM
Power Consumption: 0.16 Amp.
Air Flow: 40 CFM / 68 m3/h
Weight: 528 g
Noise Level: 0.8 Sone
Thermal Resistance: 0.18°C/Watt
Thermal Interface Material: Pre-applied MX-1 Paste
Warranty: 6 Years
Installation
Installing the Freezer 64 Pro is about as easy as it gets. There's no need to remove the motherboard from the computer,
All that is required is removing the stock Heat sink and replacing it with the Freezer 64 Pro.
Performance.
Test Rig.
Athlon 3000+ @2.3GhZ
Giga Byte K8NS
BFG GeForce 6800GS OC Unlocked to 16 pipelines 6 vertex shades.
1GB PC3200 Super Talent 2.5CL Memory
FSP AX400-PN Power supply
Codegen "Briza"
Case cooling, "2 Delta 80mm 34cfm intake case fans Arctic Cooling 8L exhaust"
The program used was CPU Burn In. We let it run for one hour, and then by looking at a program called Core Temp what uses the
CPU's on die probe to measure the temperature.
-Stock AMD Heat Sink 31c idle 45c Load
-Freezer 64 Pro 26c idle 30c Load
-Freezer 64 Pro 25c idle 28c Load After 7 thermal cycles*
Graph
http://i105.photobucket.com/albums/m240/neeksreviews/cputempgraph.jpg
(EXTRA PHOTOS)
http://s105.photobucket.com/albums/m240/neeksreviews/Freezer 64%20Pro/
Final Thoughts:
I really like this heat sink. Its very simple to install and offers the user a lot of cooling power. It can handle today's hottest CPU's or
some of today's Athlons that are being over clocked to 3.0ghz. I though i may have installation problems on a Micro ATX motherboard
but the Freezer 64 Pro fit without any problems. If your looking for a high performance heat sink that is quiet then look no further.
Pros
-Low Price. Around $34 USD
-High Performance
-Silent Operation
-Very High Quality
-Very Easy and quick to install
Cons.
-Fan Cage may interfere with high memory such as Cosair XMS on some mother boards
I give this a 9 out of 10
I would like to take this time to thank Arctic Cooling for provideing me with a sample for this review.
* Thermal cycles consist of running COYPU Burn In for one full hour then turning off the computer to let the processor col down to room tempeture.
* Pulse-width modulation of a power source involves the modulation of its duty cycle, to control the amount of power sent to a load. This information was taken from wikipedia.
For more information on this, please visit http://en.wikipedia.org/wiki/Pulse-width_modulation
The Product.
-6 6.0mm heat pipes
-Long Service Life
-6 Year Warranty
-Easy Installation
-Instruction Manual
Technical Data
Weight: 528 g
Warranty: 6 Years
Installation
Performance.
Test Rig.
Giga Byte K8NS
Codegen "Briza"
Graph
(EXTRA PHOTOS)
Final Thoughts:
Pros
-High Performance
-Silent Operation
-Very High Quality
Cons.
