This is what I ended up with excuse the formatting just copy pasting my invoice
11-129-100 CASE ANTEC|TWELVE HUNDRED V3 RT 1 $149.99 $149.99
12-200-455 CABLE STARTECH| TX3SPLIT12 RT 1 $6.99 $6.99
13-131-760 MB ASUS|MAXIMUS IV EXTREME-Z Z68 R 1 $339.99 $339.99
Click Here To Protect Your Investment
14-121-429 VGA ASUS|ENGTX580 DCII/2DIS/1536MD5 1 $499.99 $499.99
17-151-088 PSU SEASONIC| X650 GOLD SS-650KM R 1 $139.99 $139.99
19-115-070 CPU INTEL|CORE I7 2600K 3.4G 8M R 1 $299.99 $299.99
20-167-050 SSD 120G|INTEL SSDSA2CW120G3K5 R 2 $169.99 $339.98
20-233-236 MEM 4Gx4|CORSAIR CMZ16GX3M4X1866C9R 1 $159.99 $159.99
27-106-289 DVD BURNER LITE-ON | IHAS124-04 % 1 $19.99 $19.99
35-103-099 CPU COOLER CM| RR-212E-20PK-R2 R 1 $34.99 $34.99
35-186-020 THERMAL COMPOUND AC|MX-2 R 1 $8.98 $8.98
Payment Summary:
Payment Term: MastercardSubtotal: $2000.87Tax: $0.00Shipping and Handling: $11.51Total Amount: $2012.38
All in all I will say that the board features are cool as hell a lot more control over power, settings, etc etc so it was worth it. The graphics card is a beast it covers over the top of my sata ports. If the case was any shorter on the inside it wouldnt have fit.
Inside the case you have your typical cords for power, led, usb but theres an actual USB connector like what do you use that for? Like something you would plug up a external device except its on the inside of the case
Right now I have it running trials on raid 0 setup with the two SSD drives. In the BIOS theres a setting for onboard devices it asks if you want Marvel onboard driver enabled (raid, ahci, ide, sata) or disabled I guess if you disable it goes over to intel instead? Not sure. I setup a 128k stripe and my speeds are not what I had expected. Crystal mark is not picking up the drives at all so HDtune is picking them up but only showing about 220/mb where as my raid 0 WD sata drives were running at 190 on a 64k stripe. going to try different drivers or diff stripes later doubt itll make a difference.
Access times are normal.
I could not get the BIOS to see the ssd drives in the 6gb slots (1 and 2) but it sees them in port 3 and 4?? makes no sense...
Oh and its quiet compared to my old clunker
