- Jun 16, 2006
Introduction.
Arctic Cooling is a very well known company for making top of the line performance computer cooling products.
In this review, we will be looking at the 8L and 12L see if it lives up to Arctic Cooling's reputation for great
provenance.
The Product.
The 8L and 12L are Arctic Cooling's new low speed low noise case fans. These are some of the features of these fans.
-Best Noise-Performance Ratio
-Patented Case Design
-Patented Vibration Absorption
-Compatible with tool less Mounting Mechanisms for Standard 25 mm deep fans
-6 Years Warranty
-The Fluid Dynamic Bearing
8L Technical Data
-Dimensions: 80 x 80 x 38.5mm
-Rated Fan Speed: 1500 RPM
-Air Flow: 18.0 CFM / 30.5 m3/h
-Noise Level: 16.0 dB(A), 0.15 Sone
-Power Consumption: 12 V, 0.1 Amp.
-Weight: 82 g
-Bearing: Fluid Dynamic Bearing
-Connector / Cable Length: 3 Pin Molex / 400mm
-Safety Approvals: CE
-Warranty: 6 Years
12L Technical Data
-Dimensions: 120 x 120 x 38.5mm
-Rated Fan Speed: 1000 RPM
-Air Flow: 37.0 CFM / 62.8 m3/h
-Noise Level: 20.0 dB(A), 0.3 Sone
-Power Consumption: 12 V, 0.15 Amp.
-Weight: 126 g
-Warranty: 6 Years
What's in the package"
-Fan
-Mounting Screws
-Arctic cooling Case Badge
Overall first thoughts:
The fans seem very well made. The plastic is fiberglass reinforced. The rubber mounts that isolate the fan from the
mounting bracket are very innovative and the fan blades have been optimized for larger air flow and higher static pressure.r
The sleeving on the wires has a rubber type feel.
Installation
Well this is easy. just like a normal fan but do to the fan case mounting positions are limited. We could not make our computers rear
fan opening the exhaust. Instead we make it the intake and the front fan opening exhaust. They fit very nice and the cables were long enough
to mount in our case without any problems but not to long so that theres a mass of wire.
Performance.
I compared the fans with equal CFM case fans. First up was a tube i rigged a fan mount to. The idea of this test is to levitated a feather in
the long tube. First i did the 8L and marked the spot where the feather levitated in the tube and then i done the same with a equal CFM 80mm
case fan. I then repeated this test with the 12L and a equal CFM 120mm case fan.
Test Rig.
80mm test rig
6 foot section of 80mm clear plastic tubing
80mm fan mount on the bottom of the tube
120mm test rig
6 foot section of 120mm clear plastic tubing
120mm fan mount on the bottom of the tubing
(EXTRA PHOTOS)
http://s105.photobucket.com/albums/m240/neeksreviews/Freezer 64 Pro/8L and 12L/
Final Thoughts:
Why these fans may not put out the CFM like some of the loud monster Deltas they do put out a lot of air for how loud they are, I should say
loud with these fans. I tryed to hear them and failed. Every test i done i could only hear the gentle sound of air rushing by if i put my ear next
to the fan. I set the fans on a hardwood floor, in a cardboard box and on a peace of metal and even when i put my ear next to the fan i could
not hear either the 8L or the 12L. These fans put out the most CFM for there noise leva and would be perfect for those who want a quiet media
center or a ultra quiet computer.
Pros
-Low Price. Around $10 for the 12L and $6 for the 8L
-High Performance
-Silent Operation even with the fan at 100%
-Best CFM to Noise Ratio
-Very High Quality
Cons.
-Due to the style of these fans. They have Limited Mounting.
I give bolth fans a 9 out of 10.
I would like to take this time to thank Arctic Cooling for provideing me with a sample for this review.
Edit*
Fixed broken links.
provenance.
The Product.
-6 Years Warranty
8L Technical Data
-Weight: 82 g
-Warranty: 6 Years
12L Technical Data
-Weight: 126 g
-Warranty: 6 Years
-Fan
-Mounting Screws
Installation
Performance.
Test Rig.
80mm test rig
120mm test rig
(EXTRA PHOTOS)
Final Thoughts:
Pros
-High Performance
-Very High Quality
Cons.
Edit*
Fixed broken links.
