- Jan 10, 2012
the fun stuff, I have 2 threadripper builds I'm trying to keep moving along on but things just keep getting in the way!!!!!
the not so fun stuff, My people in the shops have been passing the flu around for the last month or so and that has interfered with my playtime, so if you feel ill, do your employer a favor, STAY HOME!!!!!!
The less than not so fun stuff, A delivery truck driver sent a pallet jack flying out the back of his trailer and into those of us standing around waiting for more stuff to unload and I took a pallet jack to the face and it broke a bunch of my old teeth, but just my teeth got broken, not my jaw or any bones and no body else got hurt in a major way, so later this week I'll be getting my old peoples, dentures.
The making lemon aid from lemons part, this will give me a few days to look into the cooling systems for these builds and once that's decided I can look at cases.
what I have learned in water cooling so far is that many times if you run a 3x120 rad now you get better cooling to get a rad 1 fan longer rather than staying with three fans and getting a thicker rad, do you find this also?
example, with my 9570 rig I get better temps with my 4x120, 30mm thick rad than my 3x120, 60mm thick rad.
using the 1 fan space per 100 watts, I use the total system draw from the wall and not just cpu wattage as just cpu wattage leave me running way to hot.
example, my 9570 is 220 watts at default, so i'd use a 2x120x30 rad and this is a might small for the job and a 3x120x30 would be better suited for the job. so using system wattage seems the better choice, correct?
