g0dM@n said:Thanks! I'll be ready for it. How about Prime95 priority... what does that do, and how to change it again? (i think you need a pass... i forgot) I don't even know what 'priority' really does.
g0dM@n said:Why not set them both to 10? Or wait... if you set it to 10 then only one will run, right? A 10 priority takes full control I presume.
g0dM@n said:I thought that P95 runs with high priority by default anyways...
g0dM@n said:Well, when I'm running p95 on my winchester everything else is REALLY slow... wouldn't that mean it's at higher priority? (no, I never changed the priority manually btw)
g0dM@n said:How come I hear a lotta ppl telling me to run priority 10 on it then... isn't that TOO stressful?
IronBend said:
g0dM@n said:I thought you're having one for Large FFT and the other for Small FFT. Doesn't that mean that the Large FFT will use more memory?
xTrEmEoVrClOcKr said:All I can say is, P95 let alone 2 stresses the Fets unncessarily. P95 pushes harder than normal apps so it puts a lot of stress on components ... why run 2 -_-.
xTrEmEoVrClOcKr said:Who said you had to?
