- Jun 20, 2005
- Long Island, NY
Hello,
I got a good deal on some ryzen parts but im having some trouble with freezing during prime95 tests. This has been frustrating to say the least. Was hoping one of you would be able to help as im at a dead end.
Parts:
Ryzen 5 3600
Asus b450f-gaming
t-force 3600mhz ddr4 2x16gb
lite-on m.2 sata ssd
The issue:
When running prime 95 (specifically the tests which stress memory, a small FFT test does not trigger this
system freezes for 1-15 seconds, and continues on
Also stutters while running memtest64
What have i done:
unplugged all extra components (hard drives)
reinstalled windows on known working ssd, both give stuttering issue
tested with each stick of memory separately, also tried different memory slots
DOCP has been tested both enabled/disabled. I believe i am at a limitation of my motherboard but the memory will not hit 3600mhz, max is 3533mhz.
Im not really sure what to try next other then return memory and purchase a set of g.skill 3200mhz memory. nothing microcenter carries by me seem to be on the QVL
Anyone have any ideas? I wouldnt be surprised if there was some bios setting im missing.
Parts:
Ryzen 5 3600
Asus b450f-gaming
The issue:
What have i done:
