- Mar 7, 2008
You were also using an 8 core CPU. Even with Intel, the higher the core count, the more gaming performance drops. The difference between that 6700k and a 6900k would probably be similar. Games favor high IPC, and higher clockspeeds, so that you have more of those high performing clock cycles.
If the clocks the the same and thermals are taken care of, higher number of cores shouldn't negatively affect performance. Base clocks tend to drop with more cores to help reign in that power. In the case of 1st gen Ryzen, I think I was held back mostly by the low clock wall even with overclocking. That's in part why I wonder if I were to repeat the same today with a 2700X, if I would have the same experience.
