I wouldn't call it beta testing. Maybe for the new materials such as the case for Zen 1 going to 14nm and Zen 2 going to 7nm. But outside of that, the logic and architecture is tested extensively during production phases. However, as we have made these newer processor architecture advancements, our ability to do full test coverage has dramatically decreased. I'm not aware of the coverage percentage Intel and AMD target for testing purposes on their new architectures, but from personal experience in hardware it could range from 60 to 80%. But I wouldn't be surprised if it is lower. Intel's Skylynx still has bugs coming up and its now 2 gens old.
Point is, we aren't really beta testing anything more than the new materials. The architecture is usually ok, but like you said Woomack, if they slowed down just a bit than we would see higher grade CPUs come out. Give me a $1000 CPU every 5 years but at least test it for several years before releasing it.
When I said about beta testing then I didn't mean technology in general. I know how it works. What just surprises me is how couple of years ago we could get quite good products with long internal tests ( Intel was testing some products for 18 months as their rep told me couple of years ago ) and now we get products like Ryzen line where a lot was promissed but we got most of that after 10 AGESA updates and additional fixes. I will only say memory compatibility and that Ryzen loves high memory frequency. Till this year we couldn't really see memory kits above 3200 on Ryzen or compatibility with non-Samsung IC above some frequency. Still 3600 is nearly impossible to stabilize on most motherboards.
The same is in Intel. Some updates were not tested right and some BIOS releases had to be removed because WiFi didn't work or were other issues. Some specifications were changed not long before premiere because not everything was working right. Functionality of some devices changed. Things like VROC were a total fail. Intel for a year since release couldn't say what works with what. In the end their partners were creating their own compatibility lists and said that only Intel SSD work so they won't have problems with returns.
I'm in contact with ASRock and some others regarding all that stuff so I sometimes hear things which are not meant to be spread in public. Each year we see more issues related to not enough internal tests and too fast premieres of hardware which is clearly not ready for that. So yes, we are testing many things because manufacturers had no time for that.
I can add AMD APU premiere to the list. Next fail and big problems for AMD partners. AMD didn't want to release AGESA earlier so users had problems with motherboards and partners wasted time and money on beta BIOS updates in last days before premiere. This BIOS was supporting APU but wasn't tunned right so on many motherboards were various problems.
So again. They could release less products and not so often but everything could be better prepared. There is barely any competition on the market so why Intel releases so many new processors in last years ? This is stupid. Last year we were in the point when in stores we could still see SL, SL-X, KL, KL-X, CL and some others. Really some stores were selling 6th, 7th and 8th gen chips in the same time.
Too much text, I bet that barely anyone will read that
Re new TR. You can expect OC the same as on Ryzen 2000. It's the same technology, just the same as in 1st gen TR, chips are a bit better so they can boost higher. Considering average OC of 2k Ryzen then I wouldn't count on more than turbo clock on all cores. I will be surprised if we see fully stable 32 cores at clock = turbo.
