- Jun 9, 2016
My computer locks up and continues running with last image on screen. I have to hard reset the machine to bring it out of it. It does not do it while gaming or under large load. I go to sleep watching Netflix or a downloaded movie only to wake up to it frozen. I have RMAed the liquid cooler RAM and MoBo, just to rule them out. RAM is in slots 2 and 4. I also reformatted the hard drives. After reinstalling the components the problem persists. Some times it can go 4 to 5 days straight without a problem. Sometimes it will happen 2 times in one day. I figured it had to be bios settings. I ran Prime 95 for 1 hour no problems. IF you need more data let me know.
Operating System
Windows 7 Home Premium 64-bit
CPU
AMD FX 9590 5.0Ghz 8 Core 220w
Vishera 32nm Technology
Motherboard
ASUSTeK COMPUTER INC. SABERTOOTH 990FX R2.0 (Socket 942)
Graphics
S27B550 (1920x1080@60Hz)
3072MB ATI AMD Radeon R9 280x Series (Sapphire/PCPartner)
Hard Drives
224GB TOSHIBA MKNSSDCR240GB ATA Device (SSD)
WD 3TB Sata 6gb/s
Case
Coolmaster HAF-X Liquid Cooled ATX Tower
Power
Rosewill 1100watt Modular Power supply
RAM
CORSAIR Vengeance Pro 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866
Corsair H115I Liquid Colling
View attachment HWMonitor.txt
View attachment POWERHOUSE-PC.txt
Operating System
CPU
Motherboard
Graphics
Hard Drives
WD 3TB Sata 6gb/s
Case
Power
RAM
