- Aug 27, 2002
I am getting to OC my P4 2.4C CPU. It runs at about 44 degrees Celcius idle and around 48-50 C under Load. I'm using a Alpha PAL HS with a Blue LED fan on top.
My question is what is a safe range ( desirable ) temp. for idle and load with the CPU OC'ed to about 270 mhz FSB from 200 mhz?
Also, my voltage on the CPU is at default , what is the highst I should atempt with no worries? I want this computer to run stable but at the same time I don't want to fry it prematurely.
Thanx for any advice / help.
