- Jun 21, 2002
This has been sagging down instead of running straight out of the fitting. I know its probably nothing but I just wanted to check in and see if there is a risk of leaks from it. Also the appearance bothers me but I'm not sure what (if anything) I can / should do about it. I considered suspending some fishing line from the graphics card WB to support the tubing, but not sure if placing extra weight on the card is a good idea. I also thought it could cause wear in the tubing over time since it's soft and warm and vibrations from the pump are translated through it.
