http://i153.photobucket.com/albums/s232/pazsion/samsung_n150_motherboard1whatisthis.jpg
I noticed this chip was getting hot enough to burn me, and was begining to warp the plastic again.
So i merged two scrap heat sinks, one about 2inches x 2 x 4 with fins, just enough to fit in the gap and under the plastic, the plastic held it in place, after a while it was still really hot, So i placed the huge heatsink i had on top of the HD against it, no keyboard... it continued to heat up everything over 160*
So i then forced this heatsink into a huge heat sink, 6x6x6 and about 1/8" thick ? The fins made a nice pressure fit. about halfway up the 2x2x4. this effectively drew heat off this chip highlighted here. I then removed the plastic tape, to conduct even more heat away...What is this thing?
So before i benchmarked anything, i decided to put a thicker slab of copper/aluminum on the cpu and ram...so i powered down. removed everything and put the keyboard back on.
placed some plates i cut so the plastic could hold it in place, but not alot of pressure, made sure it didn't contact anything. Then laid a plate across the ram, which i had removed and replaced, with the system off but the green light on?? bad?? Is it possible for voltage to jump off the ram to this plate, it didn't put any crazy pressure...just held in place by the ram cover, which didn't move or have to squish anything, but was enough to hold things where i left it..?
everything fit and made no contact with metal circuits...But the system did not boot, fan did not spin, HD light did nothing. After a bit the fan did spin up, but nothing else happend. The last time this happened, the ram had somehow gone bad...but i hadn't messed with it the first time it went bad...Is it posssible i messed up, all lights should be off...and this shorted something out, when placeing the ram back in, and not the heat sinks?
I removed everything, the cpu heats up, the highlighted chip heats up, the HD doesn't vibrate and there is no video
The performance had to of been 2.5x better or more with just an additional huge heat sink on the highlighted chip. I'd like to investigate more... Since the gfx are sopposed to be on chip, what is this chip? says made in china
