That's a very good cooler (handles my unlocked 6950 with ease), and it's very quiet, so you should be able to clock your 6850 pretty high with it, depending on the components used of course.
i was just planning to remove the gpu's plastic case. and manually modifying it by removing the stock fan and replacing it with a bigger one. i saw someone did it on youtube. i was planning to buy a cooler for the 6850 but at max load and like 5-8 hours gaming i get 70c max is that ok ?
