- Oct 29, 2002
- Tampere, Finland
Hello, I'm once again in need of your help. I'm putting together a computer for a friend. The parts are:
- Biostar K8VGA-M motherboard
- Seagate 160 GB sata hd
- other stuff, with no problems
Heres what happened. I put together all the parts, everything seems to work except the computer can't find the SATA HD. So I check the bios settings and under Integrated Peripherals I switch the SATA mode from RAID to IDE, as I think I'm supposed to. But after I do this the computer won't boot past the Biostar logo.
I know this is not a problem with XP install and sata drivers, the mobo simply won't find the HD. I also tried a different power plug and SATA cable, and when I put the HD in to another computer it worked fine. So I'm pretty sure it's the MOBO with the problem.
I also got the mother board switched to another of the same type from the retailer, exact same results.
What can I do, should I update the bios? Or is there some other thing I can try?
