I am going through tons of specs trying to find a low cost raid internal card for my older computer, and i got 3 headaches and no card still.
The Specs
A) 4x 2T segate SATA psudo green drives (raid capable supposedly)
B) Asus P5B-Deluxe board with 2 slots available the small 1x and the 4x video slot
http://www.asus.com/Motherboards/Intel_Socket_775/P5B_Deluxe
(specs for motherboard)
C) Future life (the ability for this same controller to work in 2 years from now, with stuff like sata3 , and larger disks).
D) USE , video editing, and storing audio and video stuff, it is very rare for my system to have millions of tiny files, usually they are bigger files, and i move stuff around a lot, even though it could have parked.
here is some of the BS that is making this difficult:
1) faux raid vrses something with a controller, a processor, and a bit of fast memory buffers. The Marketing Jerks dont want to Identify the software based stuff, so i cant figure out which is which.
(note: the software ones are still usable, and i might even use one, but it is often night and day real world issue WHEN my cpus are being used 100% and much of the buses and other operations are going continually AND i am moving data, and surfing, and watching a show, and . . .)
2) 2+Terabyte drives , and creating 2T arrays that an older system like XP can handle (without more falables).
The controller itself has to support 2+T sized drives, then make arrays with larger combinations of drives (of course). then be able to hand the OS some normal looking chunks that it wont freak out about (2T or less).
I was able to pull this off via the Intel Onboard thanks to the way they provide control of the arrays via portions of the disk used for the array.
My drives today are Only 2T, but if i have to buy a good usable card, then it will need to have LBA64 bit support or whatever it needs to handle tomorrows technology.
3) Conflicting with onboard raid item, my board should not have this problem with most of the controllers. my board uses a ICH chipset for its raid stuff.
4) Control at boot times. the not so cheap Highpoint 640 (for example) requires some BS messing with the hardware in dos to controll who gets the boot, the onboard raid or the external card. (insert various swear words for how insane it is in todays day and age to have such poor control).
I should be able to Boot to either at will, because having 2 raids (like before) i always had 2 boots, so i could jump to the backup (controller and disks) if ever any part of one would die.
5) Proper "negotiation" of PCIe when there is less "lanes". the specs for the pci-e stuff indicates that a 8x type of raid card, SHOULD work fine in a slot that only has 4 lanes available, but you and me both know that people aint following specs and proper rules and doing stuff according to the book. My second long slot only has 4 lanes, not 8.
6) money, ok its the money isnt it I was hoping to find something for around $200, but it doesnt look like that is possible. Not gonna find something USED, because it wont be the new technology :-(
7) SSD, not a big deal, i dont have enough money for 10Terrabytes of SSD, so something i want is going to be slow. A Single SSD is good and fast. so i am not worried about it now, and so far purposfull integration of SSD MIXED with HD to get the best of both worlds is not well done yet. So how it works with SSD is not an issue for me.
8) it isnt a net server, i use a backup (not mirroring). It is not for linux or unix or mac, just Winders, XP now, mabey W7 later, i dont need raid10 or 5 or 6, just simple raid0 striped for speed. Usually 2x2 and 2x2 as often 3&4x doesnt get much extra speed vrses the risk
The Specs
