- Jun 9, 2017
Can anyone tell me the screw sizes that are used for the Corsair H115i radiator mounts? The "Quick Start Guide" included with the hardware doesn't tell me. I'm thinking of designing some sort of jig that can support the radiator for bench testing a motherboard outside of the system's case, yet still allow easy transfer of the radiator back to the case without disconnecting the waterblock and pump from the cpu.
Thanks a ton
Bob
Thanks a ton
Bob
