Local hardware stores usually have screws that will work. I bought some replacement screws at one of my local hardware stores.
Lowe's or Home Depot should have some in their hardware sections.
What you need are 6-32 (sometimes marked as 6/32) screws that are 1.25" long (or about 32-33mm) and some solid washers, at least that's the size you need if you are using a standard thickness fan.
