Forgive me for I have sinned. I setup my loop (without testing outside..I know..Im MUD), everything looked great, the 'puter was nice and quiet UNTIL I noticed my rad(BIX) was leaking.
Unfortunately, it didnt get out of hand and I quickly noticed the quarter size puddle saturating one of my IP35 realtek chips and lubricating the sys fan power connector causing my fan to flicker and shut off.
I used non conductive liquid with distilled water and blue food coloring. It appears disaster has been averted. Back to the BIX leak.
One of the "barbs/thread area" was causing the leak. DD supplies you with a tiny O-ring to place between the thread area and the barb. Strangely, this worked without incident on one of the barbs, but this little PITA decided it had different plans for me.
My question is, how can I prevent the leak at the thread area? I have seen a "white gummy/plastic tape" (ie - used for shower heads) and was looking to see if that solved the issue.
Does anyone have any suggestions on what I can use for the BIX leak?
