- Jun 12, 2003
- West Orange, NJ
Hey all,
So my build got off to an odd start; the first components I received were the case, monitor, and one GPU (EVGA GTX 1080 FTW).
Being impatient, I swapped out my monitor and plugged the GPU into my current *4-5 year old* rig. (not the one in my sig)
Just the GPU upgrade from my XFX HD6870 to the EVGA card would probably have sated my gaming needs, but I set out to build a rig, and I'm going to build it!
Fast-forward to the majority of the components arriving, namely the Gigabyte GA-Z270XUD5 (with no SLI bridge), and the EKWB L360 Kit (I haven't gotten to the CPU, RAM, or HDD / SDDs yet)
I had broken down the case (Corsair Air 540) so I could see what I had to work with... and boy, was that case a mistake for the watercooling kit I had chosen.
I went to plan out the WC system... 360 rad in the front (only place it would fit), CPU block is an obvious choice for placement... but the reservoir / pump... no place to mount it! After figuring where the GPUs would go, the PSU and it's connectors would be, and other drives & fans, this case did not provide a mounting place for the L360's reservoir/pump (even with the adapter plate).
So... as much as I'd like to see the one aesthetic piece of this WC setup (the reservoir with the EK logo), I had no choice but to drill custom mounting holes in the bottom, back by the PSU and route the hoses through the wire management grommets.
More to follow!
*edit* pics added
More to follow!
*edit* pics added
