CandymanCan said:So umm what youre complaining that u cant get over 246fsb ? Gimme a break, just lower the fsb to like 240 and raise the multi i wanna see how far this cpu can go not ur Fsb.
mcoleg said:try d23 3dfire, for me it seemed to add a couple of points on fsb.
pershoot said:
it does that (or will just stay stagnant on the win screen (if u run windows.. bar wil keep moving but wont load). this was more prevalent with the 35w then it was for my 45w (but similar types of traits observed here and there). give it time. after enough nudging it will accept the voltage and go higher.
you will probably come back to or finish up on d22a1bkr2 (i switched between d22 3dfire (my old 2500+'s bios) and d22a1bkr2 a few times while OC'ing the 35w (even tried d23 subzero and d23 3dfire too for kicks (d23 didnt work very well for me on both cpu's)).
good luck man
mcoleg said:which one are you doing?
Sentential said:
**BEWARE** Checking the "voltage points" with a multimeter have been known to kill mobos. I'd ask b4 you do so
pershoot said:remember when i said, "i flashed a few times back and forth" and you will "probably finish off on ...". ya gettin the picture of the wierd phenomena which is OC'ing and and cross flashing?
i learned my lesson about flashing to d10 a while ago, haha. i see you just tasted the wrath, hehe.
i see that you were able to now bring yourself to 1.85 or so.. a few more days of pushin.. and u'll be able to bring it to 1.9 and gain that much more stability.... observe and adjust.. and youll be rockin.
you have a great shot at stabilizing 245-250 now. soon to be great OC man
