- Sep 16, 2003
- Knoxville, TN
- Thread Starter
- #41
If you notice my DIMM slots.... they are blue. That notion is false mcoleg. The new NF7 clock just fine
mcoleg said:alright! thanks man... guess i'll be ordering a new one than.
darn, that's the first m/b i've ever fried need beer...
CandymanCan said:Seems like a good cpu, but my desktop can boot int owindows @ 250fsb but after about 5 min or so of testing the thing fails, not sure if its the cpu or the motherboard or the ram, its most likely my ram since it isnt the ebst kind for overclocking.
Overall from youre results the 35watt's dont seems any diff from the 45watt.
mcoleg said:i just got stupid is all...
as for rma'ing, we'll, not too sure about it. i did burn it, my fault, you know; no rma for this guy.
of course if i couldn't buy a replacement i wouldn't have tried any mods on it in the first place.
how did your vdd mode go?
stmok said:Must...control...myself...not...to...buy...Mobile...Athlon...chip...and....have...overclocking...fun.
Must...wait...and...save...up...for...Athlon64
Ok...Opteron...dual...core...
Whew!
CandymanCan said:does Memtest86 pass ?
Ven0m said:Hmm, interesting OC and burn-in results :]
btw - often burn-in effect is not strictly to CPU itself, but thermal compound, that's known to transport heat better after running in stress conditions
btw2 - most of "common" multimeters use relatively high voltage for ohm-o-meter; professional ones usually run passive on everything but ohm-o-meter (+very high resistance for voltage check) and this test is done with lower voltage (usually 1.5v max), which is very unlikely to damage comp. So better check one multimeter with another (one running ohm-o-meter, second tests it with voltage meter)
btw3 - don't blame me for any comp damages
ares350 said:more speed captain. you got the near 250 FSB, now if you can bump the multiplier to 12.... well hot damn that would be sweet, definitly some sort of record if you do.
ares350 said:FSB is only half the battle, Ive yet to see a 3000mhz amd on something other than sub zero cooling. 250x12 would do it. though I suppose 11 would be more than respectable.
