- Jun 22, 2005
- Miami Beach
I thought 2-2-2-11 was ideal for TCCD???g0dM@n said:I'm sry about ur ram... thought you had BH5... yes, 2.5-3-3 is ideal for TCCD, but you should rather do 2.5-3-3-11 (not -7).
It depends on what FSB you're running.SoBePmp said:I thought 2-2-2-11 was ideal for TCCD???
g0dM@n said:It depends on what FSB you're running.
From my gatherings, the average TCCD/5 chip does this:
200-215mhz: 2-2-2-5
216-225mhz: 2-3-2-6
226-235mhz: 2-3-3-6
236-270mhz: 2.5-3-3-7
271-275mhz: 2.5-4-3-7
276-280mhz: 2.5-4-4-8
281-300mhz: 3-4-4-8
Again, these are rough figures I've gathered for an AVERAGE set of TCCD/5... I may be off by a bit, but it'll give you a rough figure.
And remember, when on an NForce2 (NF2) chipset, ALWAYS use tRAS of 11... if not, MAYBE 10.
Nice infog0dM@n said:It depends on what FSB you're running.
200-215mhz: 2-2-2-5
216-225mhz: 2-3-2-6
226-235mhz: 2-3-3-6
281-300mhz: 3-4-4-8
Wow, that's gonna be VERY tough, man... the NF2 memory controller already has a very rough time handling high bandwidth on anything above 2x256... When I run 2x512, I'm always disabled CPC (running 2T instead of 1T).DrSpanky said:Hey just incase anyone still reads this i got myself 2gb of Corsair xms pc4000.
boots and benchmarks at 250fsb outa the box but im getting errors in memtest at the end of test 5
tryed bumping mem and chipset voltage and its not rly helped. i may try another bios see if that gets me anywhere, if anyone has any ideas feel free to reply
g0dM@n said:Jigga... your load temp in the winter is 15c, according to your sig... eh??
lithker said:my northbridge likes a lower 1.4v when i use tighter timings. i get mem test errors at anything higher. if u r going to take everyting apart i suggest u should lap the northbridge. wish i would have, i had to use so much thermal paste just to bridge the gap.
Yup, I duct out-side with a duct fan from home depot through 4in duct pushing the air into my case. I have to leave f@h running all winter or else the water will freeze. I have a couple screenshots floating around somewhere.....
That's what I was thinkin.... good ques...DrSpanky said:dont u get condensation at them kinda temps?
