- Oct 12, 2001
- Los Angeles
Some things to consider not mentioned... the big one is headroom. If a phase unit is rated at 200w and you feed it 220w, you are borked, you will get horrid temps. With good water cooling the headroom is MUCH larger than with phase. Quad core cpu's when OC'd are pumping huge wattage... plus phase is a killer with electricity bills, then there is the noise and the condensation to deal with. Yeah if planned right you will get better temps, but you won't get that much more of an overclock for 24/7 running.
