My motherboard is an Asus M4A78LT-M-LE, and I just upgraded my RAM. I shoved in a 1333MHz dual-channel kit, and after running speccy, it's only running at like 600MHz, the same speed as my previous memory. The motherboard does support up to 1333MHz speeds.
I went into the BIOS and found the settings for overclocking the Memory, but the highest I seem to be able to set it to is 800 (which I have it at now). My motherboard supports these speeds, but I can't make heads or tails of some of these settings. So, collection of my BIOS screens that I found:
http://www.motherboards-reviews.com...78LT-M_LE/ASUS_M4A78LT-M_LE_BIOS_screens.html
Any sort of help would be really helpful, and I appreciate it a lot. On a second note, quick question: I'm playing games and livestreaming it at the same time, but my used RAM never goes above 4GB. If I had known that my used RAM would never go above 4, I wouldn't have bought 8. Is there any way I can actually use the extra memory that I have?
