- Dec 20, 2001
Can some one link me to the website that has the seti caculator that estimates your time for certian WUs.
Wolverez said:Is this the one you are looking for: http://www.alistairbraidwood.com/html/seti_timer.html
Glad to be of some help...{PMS}fishy said:
Yep thats the one. Thanks.
Well, what is the AR of your current unit? Something around 11+ could very well take two hours less.craigiz1 said:I get a 2 hour difference between AR's. If I use the default AR, I get almost exactly as SETI Spy indicates. If I put in the AR of the current w/u, it shows that it should be completed 2 hours faster.
Any ideas why?
TC said:Well, what is the AR of your current unit? Something around 11+ could very well take two hours less.
TC said:I'm pretty tired, so I may missing something - but this sounds like an issue with the seti spy calibration. You have to calibrate spy for your particular system.
yes. that's the only way I can get realistic times, so I'm assuming you are correct.Demont said:when they say "Be sure to enter the effective memory speed, taking into account the double or quadruple data rates of DDR and RDRAM memory." do they mean, 266 by doubling for ddr, or 133 by halving for ddr?
oops... I guess it helps to read sometimes . {PMS}fishy was right, though- you should use 266.Demont said:
errr which one is it? of course one of my thoughts is correct i just dont know which 266 or 133?
