Hi everyone,
I'm currently on the market to get a triple + one monitor set up and a new graphic card to withstand this set up and I need a little help.
So here's the run down, I want to run 3x Asus VX238H plus a LG 42inch TV (full HD), the TV is just off my viewing angle and is not generally used but I'd like it to be connected and working at all times since it comes in very handy, the 3 monitors will be side by side. I don't want any clone screen, I'd like to have them all in a extended set up.
Even though I will be gaming I just want/need the center monitor or the TV running the game so the other monitors will just have internet pages open or Teamspeak or something similar.
As for the graphic card I have in mind in getting either 2x GTX 760 right now or 1x GTX 770 right now and add another one later (3 months down the road).
So here are the questions:
1- Is it possible to set this up?
2- How do I connect all those monitors to either card set up, what adapters do I need? (the TV will run on the HDMI)
3- Do I connect all the monitors to the same card?
4- I know that in SLI only the master card uses it's memory so I'm thinking of getting the master card with 4GB and the slave with 2GB is this ok and possible, or just a bad idea? The cards in question would be a EVGA GeForce GTX 770 4GB Dual Classified with the EVGA GeForce GTX 770 as for the 760 it's the EVGA GeForce GTX 760 4GB paired with the EVGA GeForce GTX 760, please notice that these cards may run on different speeds, is that a problem?
The motherboard can take SLI set up and so can the power supply.
I can't think of anything else but any advice is welcome
Thank you!
Thank you!
