- Jul 5, 2012
Wasn't sure where to put this so sorry if I've gotten the wrong area.
Hi, I'm new to the forums here and for a while I've been wondering if I'm really get the most out of my system. Here are my current hardware stats:
Mobo: Gigabyte GA-990FXA-UD3 http://www.pccasegear.com/index.php?main_page=product_info&cPath=138_1207_803&products_id=17527
CPU: AMD Phenom(tm) II X6 1100T Processor (6 CPUs), ~3.3GHZ (Not OC)
GPU: Gigabyte Radeon HD7970 Overclocked 3GB http://www.pccasegear.com/index.php?main_page=product_info&cPath=193_1309&products_id=19269 (2 Monitors)
RAM: Corsair CMX8GX3M2A1333C9 8GB (1333MHz) (1.65V) (4x4GB) DDR3 (2x http://www.pccasegear.com/index.php?main_page=product_info&cPath=186_218_1125&products_id=15517)
Sound Card: Auzentech X-Meridian 7.1 2G (http://www.pccasegear.com/index.php?main_page=product_info&cPath=211&products_id=16247)
CPU Cooler: Corsair Hydro Series H70 Core CPU Cooler http://www.pccasegear.com/index.php?main_page=product_info&products_id=19073 (Runs with 2 fans on either side)
Fans: (apart from the CPU cooling fans): 2 Outtake fans on top, 1 intake fan on the front.
PSUs: CoolerMaster SilentPro M 1000W
Temps: Whilst idle, CPU stays around 19-24 and GPU stays around 39 to 45. Under load (So far only tested it with GTA IV at full with a movie playing on the other monitor) CPU can get to 30 and GPU can get to 50. (I'm sure that the CPU would go to about 50 when rendering movies at full).
I realize that my RAM being at only 1333MHz might bottle neck my CPU, is this true and if so should I overclock? (I do have a spare ram cooler, currently not installed). Should I also think about overclocking my CPU? Also my GPU is built to be overlocked but as my last one overheated and died I've only been running the current one at a normal core clock (900) however it can go up to 1100.
(On another note, I'm obsessed about Anti-Aliasing and always play on full if possible, which means my FPS can suffer every now and then)
Anyway that was my wall of text. I would appreciate any advice on overclocking any parts of my system and thank you to anyone who has gone out of there way to read over this topic. Cheers, Splinter.
