- Nov 19, 2005
- Thread Starter
- #21
Well you have a dual core so you can run prime on one core while doing w/e on the other core.
Michael Warren said:Well you have a dual core so you can run prime on one core while doing w/e on the other core.
I have heard of people running the single core original version of prime and testing both cores seperatly. You might not know this but prime utilizes 100% of the core that you are running it on so you cant really do much but let it test. I can normally surf the web or do w/e while running prime but thats because I have 2 gigs or ram and my OS isnt clogged up with junk.Xstatic said:What difference does that make? I thought single cores could multitask just as good as dual cores? And when you prime with dual cores you prime both at the same time not 1 at a time.
Michael Warren said:Wow who told you that single cores can multitask better than dual cores. I cant believe that you believed them. LMAO
squads said:I figured i'd mention that my rig right now is dual prime stable but I can't run 2 instances of superpi. It errors immediately when I run 2 (each assigned to a separate core), so I think there might be some problem running 2 at once with a dual core. Anyone else run into this problem?
Michael Warren said:I can normally surf the web or do w/e while running prime but thats because I have 2 gigs or ram and my OS isnt clogged up with junk.
GM1010 said:It's really a personal preference and determined by what you use the computer for. I don't run my computer at anything that isn't 24 hr prime stable, but that's because I fold 24/7. If it's crunching something for 12 hrs, and prime fails after 2, well you can see the problem. For people who only game and use the internet or whatever, a few hours is more than enough.
Again though, the longer it's prime stable, the less chance you will end up corrupting some random important Windows file down the road.
Internal said:I personally believe in a 100% stable system even if it means I have to back off from an overclock I REALLY wanted.
GM1010 said:My computer works just fine when running prime.....I don't know about yours.
hawtrawkr said:something to think about is this. i myself dont know of anyone who has run prime95 for 24 hours without an error and couldnt run a benchmark or failed a superpi calculation etc etc etc.
RoadWarrior said:Well you do now, hi!
I wasted 2 weeks "priming" one rig on and off. overnight runs, 24-36-72 hour runs. Solid as a freaking rock in prime95, but couldn't get through more than one pass of 3DMark2K1, I could also lock it up within 5 mins by running Toast and Sandra benchmarks at the same time. I therefore mistrust prime95 as an "ultimate" stability test. If it fails, you've got serious issues, but if it passes, it doesn't mean squat. Not saying 3DM is ultimate either, I've seen that run where other benchies fail. I myself don't bother with it now, I prefer looping other benchies while toast is running, seems more severe. I'll also note that every AMD XP rig I've got here, if it will load win98SE without throwing a registry error when overclocked, it will run prime95. I could have claimed OC glory back in the day by a screenie of 24hr prime95 on an aircooled pally @ 1.9G, but I didn't because I knew it didn't work worth crap for anything else at all, (Explorer would keep bluescreening for fricks sake) "stable" was back down at around 1766.
IMO prime is outdated and a waste of time for determining true stability, use something more intense in the first place. On my CPUs it runs about 8C cooler than Toast and 5C cooler than folding gromacs, to me that's not a sign of something that stresses your CPU to the max.
Road Warrior
hawtrawkr said:you still only have the one memory controller even with the 2 cpus when you run 2 instances of superpi it puts a tremendous strain on the memory controller and that might be exposing some instabilities. try backing it down 5htt and see what happens or at stock speeds even it should be able to run both to a point but the numbers wont be stellar.
