Trypt said:
A question: Will p95 eventually crash no matter what clock you're using?
No!
Or, perhaps more accurately: "It shouldn't".
But, as Murphy always eventually wins, yeah, somewhere down the months or years, sooner or later, a computer crash inevitably will happen, just as computers that don't run Prime95 eventually crash, sooner or later, too, even though they "shouldn't".
But let's not lose sight of the fact that Prime95 is foremost a GIMPS Distributed Computing Client!
It is intended to be able to run 24/7/365, while searching for Mersenne Primes. Prime95 should "technically" run w/server app type "uptime", given a suitably stable machine. As I stated earlier, the keyword is "technically". It's impossible to keep Murphy at bay, indefinitely, for an infinite period of time.
The "torture test" subset of the Primwe95 software is simply a utility for a prospective GIMPS participant to test/validate the stability of their machine(s), prior to deploying GIMPS, or, for a current GIMPS participant to validate a new or questionable machine, for whatever reason, for GIMPS deployment, without actually running a live Work Unit, possibly producing bad science.
The fact that it has become a somewhat de facto stability test piece of s/w, is actually an unintended consequence.
Many ppl run Distributed Computing 24/7. I AM one of them.
Many ppl run GIMPS 24/7. I am NOT one of them.
However, a team on another tech board that I am associated with, does have a very large GIMPS team w/several hundred machines running GIMPS, many of them 24/7, and they do often run 24/7 for quite a few months, until s/w updates, system maintenance, or relocation, etc., require a shutdown or reboot.
BTW - If it seems Distributed Computing peeps are stability freaks, you're right, they are (at least the ones that care about producing good science, rather than simply being a stat's wh**, at all costs). The last time I popped in on my Distributed Computing team's GIMPS thread (approx one year ago), it took ~ 3 weeks to check a single GIMPS exponent (Work Unit) on an average computer, to determine if it's prime, or not. If it is (lucky you - your name will be recorded in mathematical sciences for posterity - & you may receive a substantial sum of money!), it will then be sent out to other machines w/different architectures & OS's, for verification (called "re-checks"). But, during those 3 weeks you were crunching that exponent, all it takes is 1, yes ONE, bit to be off, to throw the whole show down the tube. Imagine missing finding "the big one" (
250K U$D Reward - BTW ), due to your machine being off one bit!!!
Anyway,
FWIW
Strat
