Look at the picture I attached. See where it says PULL? That is a pull configuration.
Uhhh... it goes wherever the fan is pointing...yes i see so if i can only do pull configuration then the air goes up
is a push pull better than just a pull configuration though?
I know. I read your other thread on essentially the same subject already...
nope, just pick a different radiator.
Nothing wrong with pull. You do not need every degree C it MAY benefit. You are not breaking records. Just run what you have in a pull config and you should be fine.
