My question is can I fit all this on one loop?
no desire to put dual loops in this small case.
I plan to build into a Lian Li PC-Q37 Mini ITX case. I will be drilling through the case
to help keep tubing clean and to a minimum length necessary. I'll be using a Nemesis
GTS240 radiator with 2 proper push fans, EK fullcover GPU block, CPU block, and Monarch
memory waterblocks. Once I get the case and measure it'll probably be between a 100mm
and 150mm reservoir, 16mm OD tubing, and Mayhems' coolent. Most likely a DDC pump but
I have seen the D5 fit in this case. The radiator will exhaust from the top and I'll have two
slim 120s on the bottom as intake.
Here is an example of a similar build by RyanEL. I'll have the same top radiator and same position
of the reservoir but the pump will be in the back compartment.
I've built many air cooled computers and have been wanting to build my own dream water
cooled computer for a while now. I love the design of the new EK Supremacy Edge Plexi
CPU blocks so I figured I'll snag one before they're gone forever and start my build.
- i7 8700K OC 4.7-5GHz (I will delid it)
- Single 1080Ti or next highest end GPU below Titan
- 2 Dimm's at 4000Mhz
