- Sep 4, 2002
- New Zealand
This is quite a strange problem. I was running Windows 2000 on a Seagate 7200RPM 40GB drive. Needed more space, so I bought a Western Digitial 80GB drive. Cool, I get an 8mb cache and decide to try out Windows XP. The drive was partitioned into 10/10/10/50 NTFS.
However things weren't quite right. WinXP would take several minutes to load up, and things seemed pretty slow. It was only HDD things that seemed slow, processing tasks are fine. I tried to run SiSoft Sandra File System Benchmark, but it was taking ages. I eventually did get a score of about 2mb/s after over half an hour. Another benchmarking program showed it running at 1-2 mb/s.
At first it seemed that the partition setup was slowing things down, because when I formatted and reinstalled with just a single partition and it seemed ok. However I've done quite a few reinstalls since then, and now even when I'm just using one partition its slow.
The drive itself is fine, if I boot in to my old OS (which fortunately I didnt delete) I can bench it as a slave and it scores about 35mb/s (almost as good as the raid setup!). HDD diagnostics can't find a fault either. I've also already had the drive replaced, but symptoms are still the same
As far as I can tell, it's some kind of weird Windows problem. Service packs, drivers, etc don't seem to make a difference. Any ideas?
Athlon 1800XP
Asus A7V333
2x256MB Kingmax Memory
Leadtek Ti4400
WD800JB
Seagate Barracuda IV 40GB 7200RPM
Creative Soundblaster Audigy
Athlon 1800XP
Asus A7V333
Leadtek Ti4400
WD800JB
