- Feb 29, 2004
ok here is aLINK to a pic of my setup that i want. Ok after seeing the setup i'm haveing problems getting into the firewall via web admin, So here is how i have it setup, my cable modem comes inro the red zone on firewall then coming out on my green side to my linksys router, the router is my dhsp server, now coming out of my router to my 4 port linksys switch. I'm using to realtek nic card one for red and one for green both are seen by firewall. Now the biggest problem i'm haveing is getting the PC's to get a ip from router that is usable. I have found that when i connect the cable from the green zone one firewall to the wan on router i get no act light and if i connect it to the uplink on switch, is this because i'm not using a crossover cable or a wrong setting somewhere? I'm kind new to the linux world and i'm sure i'm missing something here so any help would be great or a small run down on how i should set this up.
