- Oct 30, 2009
Sleeve bearing fans can't push air up without dying before their time, right?
Sleeve bearings mean that when a fan is placed label side up the shaft hags from its retention disk. Since a retention disk is made out of plastic, and because when it is pulled it compresses the shaft, it is not a very good bearing.
Antec's TrueQuiet Pro may have fixed that. They have a 5mm magnetic disk that is strong enough to hold the blade assembly up against the frame. I discovered it when I was doing this review.
It's actually pretty cool. They may have fixed the sleeve bearing problem.
Too bad the fan is so expensive, though. Probably because the disk is some rare earth or other.
