Hi, my CPU died on a 2.5 year old build, so I bought a new Mobo and CPU Hero Maximus Xi Wifi and an I9 9600 KF. I haven't kept up with new tech since my last build.
Stupidly, I did not consider the slot configurations for the PCI E cards and thus my cooling terminal connector between the two GPUs is too big.
So I'm going to order a 3 slot from EKWB (unless you guys tell me not to as below).
So some questions:
1) Should I use the first and second x16 PCI Slots? (as opposed to 1st and 3rd, 2nd and 3rd). Does it matter?
2) The MOBO manual says the SLI bridge included is an HB Bridge. Previously I had to buy a third party (EVGA for me) HB bridge. The one I have now is too long. Is the included one ok/equivalent (that would be cool)
3) There are two M2 slots (which I had to remove a cover for, which looks cool but had me way confused for a while). Does it matter which one I use? I seem to remember that M2 could interfere with USB or something but I assume that's been sorted for now).
I know some of these questions are pretty basic but I have lost a lot of build knowledge since I last made on.
So some questions:
