- Feb 27, 2016
AMD has integrated graphics also.
They're better than Intel's.
Sort of, but most tend to take more watts...
There is no comparison. They're much better. You have to give a little to get a little.Sort of, but most tend to take more watts...
ask the minority that got hammered by this. they'll tell ya.
what i do know for sure is, when a small minority of people have problems with a driver or piece of software and millions are running it fine, it's them. somehow. and the possibilities are near infinite.
??? Interesting viewpoint.
hell..sometimes it's something as simple as they didn't want to move the HDD's around so they installed that larger, new video card down in the 2nd or 3rd PCI slot instead of #1 and something between the driver, MB and card Just Didn't Like It.
I think back on some of the things I did in the past to get systems working and it's just astounding how weirdly these things can interact sometimes...especially with the bargain priced components.
Seriously?
I connected my multiple monitors, according to their spec.
I activated my multiple monitor setup, using their software.
I update my driver, using their software.
I get stuck in a BSOD loop.
So how is this my fault (other than clicking the install button?)
Seriously.
IF this was only for a specific brand of monitor on a specific motherboard...you MIGHT (key word MIGHT) have an argument.
Did they let it slip by. Yes.
Are they still responsible for making sure it works. Yes.
Geeze...have you ever had a recall notice on your car?
Wow.
Nvidia had mentioned that it was in the installer I believe.
This has nothing to do with Jimmy rigged anything.
There's no need to take it all so personally.
I was just trying to share my experience of how these problems can be caused by some odd things that you might not be inclined to put together at first.
A less than perfect driver may have highlighted a weakness somewhere and I'll bet a nickel if I could have sat down in front of your system I could have made it work.
I'd win that nickel because I've won that nickel a thousand times.
Let's not argue though..the proof of that would be in the fixing and there won't be an opportunity for that so...
You would not win that nickel...and I did make it work. (See my original post).
I know what I'm doing as well...I'll post my resume too if you want.
