- Sep 19, 2002
- CA, USA
Well, in the case that I don't want to spend ~100 bux for a meanwell PSU on a peltier...I though about building one..then I noticed my extreme lack of electricals and such, yes I can solder but it ain't too clean.
Information:
Then I thought, well this 226w pelt from DangerDen draws 24A , then I looked at a PSU spec sheet setup by Penguin4x4 who's amperage on the 350W PSU were the same, (the EG365P-VE FCA) which happens to run at a max of 26A, and the max of this peltier is 24A.
I will be watercooling the pelt after I get some funds for the wc, then a month or so later I will add the pelt. But I will be watercooling the pelt, and I don't think my 2100+ @ 8X200 1.95vcore will get much over 83W (using a calculator from http://www.benchtest.com/calc.html ). 82.67 was the wattage it gave when I put in in the clock speed and the vcore.
Question:
Now, after all that explaining, what I am wondering is if the peltier shown above will run off of the PSU also above? The peltier will not need to be moving all the energy over, becuase there will not be that many W to remove...so will it still remove that energy or will it just not need the power to do it?
The only thing being insufficient in this setup is the voltages on the PSU, noting how the largest rail is 12V, and the max draw on the pelt is larger than that, so is there a chance it will kill the PSU? Should I look into buying a meanwell psu or something like those?
Sorry for the overly explanatory post, but I wanted to make sure the reader(s) got all of the information necesary...
Thanks in advance!
Fold and Frag on
Brian
Information:
Question:
Thanks in advance!
Fold and Frag on
Brian
