- Apr 19, 2012
Looks pretty good Silver_Pharaoh!! This thing is gonna clock like mad!
Almost to the point of being unbelieveable.32c on 1.55v.... Im extremely impressed!
Maybe. I have dual cores that run hotter than that on better cooling. Need to get into that over 40c range to get more accurate.small fft run with half the cores disabled. Seems feasible enough. You thinking theres just an error there?
I'd like to see 6 threads for an hour or so.
OK. Saw what I needed. Thanks.And here it is:
I came back to a crashed Prime95
Seems it needs more a step more Vcore to run all 6 cores.
For my daily overclock/use though, I'll only be running 3 cores. Maybe 4.
But yes, with all 6 cores enabled, seems that this would be the highest I can go..
Something to consider Kyle...
If you only plan on running a few cores for 24/7 use (folding or otherwise), my FX4130 was only $40 at MC. I run it 24/7 at 5.0@ 1.50v with my Noctua and when benching on ambient water it runs most benches at [email protected]. Let me see if I can find a sub or 2. These chips are great for everything and I'm really surprised they're not more popular.
EDIT: http://hwbot.org/submission/2700898_blaylock_superpi___1m_fx_4130_15sec_547ms
http://hwbot.org/submission/2700145_blaylock_superpi___32m_fx_4130_14min_40sec_203ms
http://hwbot.org/submission/2691525_blaylock_cpu_frequency_fx_4130_5600.7_mhz
whoa. silver, whats up with your -12v?
haha yah like ATM says it's the softwarewhoa. silver, whats up with your -12v?
Worked it slowly from 1.55 volts Shrimpy.Look at that Full advantage of shutting down cores!!! Nothing wrong with that at all.
I'm curious about voltage. Did you pump it in hard, or gradually work up to that to find stability? This clock should be higher, or lower voltage IMO.
You need a better (Asus) motherboard. That UD3 is doing you no justice.
Temps are good, but when do you get concerned about die degradation?
