You have the infrastructure, you should simply sell the 6300 and get an 8320.
The problem with low chips is that they're all octo core chips that didn't make the cut
Hmmmm..........
Link to proof please.
IIRC RGone mentioned that in a post.Hmmmm..........
Don't see the point honestly. Clearly 83x0s clock significantly higher (which is what you want?)
For example, mine runs 5400 at 1.55v. No clue what 1.66v would let it get to....
The chip under the IHS is the same size on all FX's I've seen delidded.
NP.Sorry, I would have found links (and planned to when I got home, which is now), but I was on the OCF app on my phone when I posted that earlier.
NP.
Rock on.
Lol.I think we should say "Clock on!"
What's the IC? (Check it by the serial)
9-11-10-28 @ 1866 is another standard timing set from G.SKILL.
If you have a set that's the same IC's they used at the higher timings there's a good chance you can run those same (or close to the same) timings.
