interesting.......don't nvidia know this happens??
can't they stop it??
Its not just nVidia. It happens with ATI and all make of motherboards as well. They all buy the series inductors
for there on card/MB Vcore power supplies from the same vendor set
Inductor singing is highly variable and varies radically from card/MB sample to sample. One card/MB may sing
like crazy while another, using the same parts, doesn't at all or is barely audible. The case the cards/MB's are
installed in and their position in relation to your ears can effect how good or bad the singing appears to be.
If your particular card is really bad you can RMA it. Moving the computer case to a different position in
the room may do wonders in making it sound better (or worse). Slight changes in position. either you
or the case can make large impact in the sound you hear. The singing sound can be very directional and just
rotating the case at its current position can change how your ears perceive the singing.
Just be aware that no GFX card (especially power hungry top end cards) and/or MB's are immune from series
inductor singing. There will be samples of all of them that sing to one degree or another while others will be
virtually silent.
Viper
