I have a OCZ Vertex 2 120 GB SSD, which i would like to install my Windows 7 Pro on it, and use it as my OS and apps drive. I then have 4 250 GB HDD's (2 Seagate and 2 Western Digital Blue), and i would like to RAID 0 these drives and use them as my data storage.
I have played around in BIOS for a bit and came to the conclusion that, i can only setup RAID 0 in BIOS IF I boot from the RAID drives.
What i have currently done is, installed Win 7 on my SSD, then plugged all drives in, and changed the SATA mode to 'RAID' in Bios (For my HDD's) then i hit Ctrl + I to set up raid. I Then select just the 4 HDD's and i setup RAID 0. THEN, when i boot from the SSD, the 'Starting windows' logo moves for about 2 seconds before it freezes, and a blue screen (Looks blue screen of death) flashed for a micro second.
HOWEVER, when i change the SATA mode BACK to ACHI i can boot from the SSD fine.
Basically, by changing the SATA mode setting i can either, boot from an SSD and have no raid, or have RAID but no OS.
Is there a way to, Boot an OS from a single SSD, whilst having a RAID 0 array set up purely for storage?
Thank you so much.
Thank you so much.
