Yes sir, I thought it would be best to have the fan blowing air over the radiator that pulling.the aio on top is blowing in the case, right?
Do you think the CPU will be ok if I am pulling air instead of pushing air?, so you want that facing upwards.
Thanks...Also, nice counter tops
Blaylock, thank you for taking an interest in my build! I will take any advice I can get.OK, here are a few suggestions...
I tried that at first and I could not get the connecter through that opening. I will try it again and see if I can get it to work.1. Try running your motherboard power cables (EPS 8-pin x2) along the back of the motherboard tray. (notice the opening just above the connectors.)
This is good stuff! I will do that for sure!2. Flip your PSU over so the fan is sucking cool air in from the bottom filtered intake.
Thank you, I am very excited about it. My CPU should be here by the 1st. Then I can fire it up and see if it works.It's gonna be a sweet build for sure.
