- Jan 12, 2012
nice always wanted to grab one of those.
The NB voltage is 1.175. I went back to 4.4 but haven't run more than 30 to 40 mins of prime. I dropped the vcore where I had it when it was running at 4.4.I think the vcore is at 1.428. The next setting on LLC is extreme. That may be too much.
- - - Updated - - -
You're welcome.
Let me know how it goes!!!!!
- - - Updated - - -
I put it back to 4.4. I'll run it when I get home to see how it does.
It's all about the target voltage, and whether it's stable voltage. Let's try setting llc to extreme, then say our target voltage is 1.428 @ 4.4gHz. That means we don't want the vCore to drop below 1.428 if we can help it. You said you had it set to extreme and it shot up to 1.48 under load, what was it set too? Let's try setting CPU voltage to 1.38 and see what it hits under load. Adjust it up or down until your steady at 1.428 under load.
Now for CPU_NB voltage, with "high" speed ram bumping it up can be beneficial. You can probably set that up to 1.3v without a noticeable increase to temps. You can work it back down later, but for now give it plenty of juice just to make sure it's not a limiting factor.
Run it at least 2 hours so you have a known stable Oc. I find it makes pushing further a lot easier, when one has a fall back oc, especially when trying to see how far you can take it.
Ok good, temps look good but not sure if you have enough headroom for 4.5 Ghz. I'm not liking the V Droop you're getting but if it passed then no reason to work on it unless you start having stability issues. Where is the Nb Frequency set?
Ok good, temps look good but not sure if you have enough headroom for 4.5 Ghz. I'm not liking the V Droop you're getting but if it passed then no reason to work on it unless you start having stability issues. Where is the Nb Frequency set?[/QUOTE
I have the Vcore set to 1.3500 in the BIOS and LLC to extreme that why you see the low vcore. It goes up when loaded. If i set the vcore to 1.3625, the vcore goes to 1.428 to 1.440 and temp hits a high of 57C. I can bring the vcore up in the BIOS and go back to an LLC of medium. I have the NB freq at stock which is 2000. Can it be raised to help performance? The CPU NB is set at 1.200 v.
Ok got ya, I personally do not like to have big swings in voltage like that. I'd rater have my voltage set a bit higher and have the LLC keep the voltage close to where it is set. Nothing wrong with how you have it set but if you find that you have an issue with instability you may be better off setting the Cpu voltage higher and dropping the LLC down a bit. What you're doing now is setting a voltage in the motherboard and relying on the LLC to give the Cpu enough voltage to maintain the Oc. Again, if you don't have any issues with instability then it's fine where it is.I have the Vcore set to 1.3500 in the BIOS and LLC to extreme that why you see the low vcore. It goes up when loaded. If i set the vcore to 1.3625, the vcore goes to 1.428 to 1.440 and temp hits a high of 57C. I can bring the vcore up in the BIOS and go back to an LLC of medium. I have the NB freq at stock which is 2000. Can it be raised to help performance? The CPU NB is set at 1.200 v.
