I'm having an issue with getting my caching to work. I've done every step and tried pretty much all I can think of. I have the latest version of the RST utility, latest drivers, both my OS HDD and my new SSD plugged into the intel SATA ports on the mobo, I have my bios set to raid configuration, and I edited the registry setting as I am adding the SSD to my existing W7 install. The problem is, when I open up the Intel RST utility, it shows both my drives as 0gb and everything unknown and am I unable to set them up to cache. The accelerate option doesn't show up either. Any thoughts?
Updated to newest bios version which "Improved Intel RST support" so it seemed promising but still no luck. I'm pretty much out of ideas. Just to confirm, when you got yours working were you set to ACHI or RAID mode?
Personally I would set up caching with that setup. Why not speed everything up instead of just the OS? Plus I like to have min 100GB for an OS anyway. I always used to run out of space when I ran OS from a 64GB.
Rule of thumb for me is 64GB use for caching, anything bigger use for OS.
If you're running things off of D:, then configuring that to use SDD caching will speed those things up.
It will speed up data load times for anything on D:, and speed up save times if you use the more aggressive option (Enhanced).
Your OS and boot times won't chance since you've already got that on SSD. But you'll certainly gain something from the rest of your PC by using ISRT.
NOTE: I'm assuming you've got extra capacity or a second SSD to use for caching your D:.
Just be aware that you'll need to partition your SSD for the amount you want to use for ISRT. Once you have a blank partition on your SSD, you can run the IRST manager (from your task bar icon) to accelerate the D: using the blank partition on your SSD.
This is to the best of my knowledge. I haven't actually done this yet, but every indication is that this will work (assuming your BIOS is already set to RAID, your SSD is attached to the Intel SATA ports as well as the HDD you're trying to accelerate).
Good luck! And let us know how you make out!
PS: I would love to strangle the idiots at Intel that decided to use nearly identical names for their two related but not-same technologies! It's impossible to remember which is which (IRST/ISRT), and takes tons of mental cpu-cycles to distinguish and recall which is which! Ugh!
IRST = Intel Rapid Storage Technology (their SATA controller & driver technology)
ISRT = Intel Smart Response Technology (the SSD caching technology, aka Accelerate)
I originally picked up a Corsair Force Series GT 240GB SSD drive and installed the W7, office and other programs on it.
Recently I purchased a Western Digital Caviar Black 2TB HDD as I was concerned about the SSD getting filled quickly.
So for large programs like games etc, I figured I'd just install them on the 2TB HDD.
Would it be beneficial for me to cache the 2TB hard drive to the originally installed SSD drive? Or should I just leave it as a separate drive?
Just leave it is my advice.
Thats how it has to be setup to work. There is a way around that, but its a convoluted install process to accomplish it. With a 240GB drive, how/why is BF3 NOT on it in the first place?
