- Feb 26, 2003
so this optimized stuff, just drop in those files and run the manager as normal? or do i run the downloaded optimized .exe files or something....
just want to make sure
You got it right the first time - copy the files and run the manager as normal.so this optimized stuff, just drop in those files and run the manager as normal? or do i run the downloaded optimized .exe files or something....
Not really. As has been said, BOINC is very easy to run. The fanciest "trick" we have is running an optimizer, currently the AK_v8. Those do get improved every so often but this one is relatively new so I don't expect any changes for awhile.Hi guys, I kinda am with Mr. Guv on this, F@H as great as it is is too ridiculous to keep up with and leads to too much maintenance of file and system clutter, what with installing this and uninstalling that every week. Anyway, I figured I'd give this a shot. I think I've got it running correctly. Any tips or pointers, or things I need to do to helps out?
I suppose optimizing your system (cleaning up services, cutting down on virus scans, etc.) would be recommended but you F@H guys probably know that already ...
Awesome, this'll be fun. A program that doesn't need a nursemaid Stanford should take notes.
Hello all..new to the forum and I thought I would post this link for the Cuda optimized app (it installs itself) just go threw the steps on what you want to run.
http://boinc.dnsalias.com/
Its at the bottom of that list called "64bit Unified Installer (APv5 32bit, AKv8b 64bit & CUDAv11)"
This is for both CPU work and GPU work..just pick which one you want..or if you want to run both pick both.
Says Page cannot be found when using that link
