- Sep 8, 2005
- A Town : |
Alright. I'm sorta at a crossroads here.
I recently fixed a major heat issue with my cpu and started to circulate more air into my case with an extra fan. I figured that one case fan would be an awesome addition and would help out a lot in the circulation department, seeing as how I only had one exhaust fan and a cpu HS fan. And while it does help, IT'S NOSIER THAN HELL!
The case fan I added is positioned on the side panel, above the cpu. This particular fan also has a straight plastic duct attatched to it. The duct itself came with the case so I figured I'd put it to good use by directing airflow over the cpu's HSF.
The hole it moves air through is not completely free of traffic. As oppose to being a perfect hole, it's more of a preforated hexagon, with the holes evenly spaced from each other.
Out of all this, I want to ask two questions:
1) If I were to dremel away the preforated metal that sits in that hexagon, would that bring down the noise level?
2) Is there a such thing as a quiet, but high cfm fan? If so, I could replace this loud side panel fan with maybe a more quiet giant. If it doesn't exist, though, maybe I could just put more lower cfm, but quiter fans.
If any of you have squashed both a noise problem and a case circulation problem, please let me know what you did. Thank you.
