- Dec 27, 2008
Newb overclockers often are at a loss as to how to attach spot fans when we suggest they need extra cooling to the VRM area. And of course the variety of shapes and configurations of VRM heatsinks means that no one way will work. So, here's another approach to that challenge when the heat sink has no flat area for adhesives and the fins are all vertical. This method involves two short screws that grip the walls of the fins with a stout rubber band stretched between them. The rubber band is then stretched over the corners of t he fan on the underside so as not to interfere with the blade rotation. This is being employed on an ASRock 970 Extreme 4 which I am planning to pair with a Zambezi 4130 and overclock. My biggest concern is that the rubber band will break and I suppose one could use small zip ties or something instead. But the tension produced by the rubber bands is nice. Maybe some small coil springs would also work and be less likely to fail.
